bsublett
Aug 18, 2022Aspirant
M4250-26G4XF-PoE+ showing TLS 1.0/TLS 1.1 vulnerability
My Tenable scan shows that all of my M4250-26G4XF-PoE+ switches have the SWEET32 vulnerability. When I look at the HTTPS cert it shows that I'm on TLS1.2. How can I set the minimum version to exclu...
schumaku
Aug 18, 2022Guru - Experienced User
Realized there are two device WebUI on these switch model lines? The classic config Web UI, and the other AV Web UI ... the second is not updated.
