bsublett
Aug 18, 2022Aspirant
M4250-26G4XF-PoE+ showing TLS 1.0/TLS 1.1 vulnerability
My Tenable scan shows that all of my M4250-26G4XF-PoE+ switches have the SWEET32 vulnerability. When I look at the HTTPS cert it shows that I'm on TLS1.2. How can I set the minimum version to exclu...
schumaku
Aug 18, 2022Guru - Experienced User
Realized there are two device WebUI on these switch model lines? The classic config Web UI, and the other AV Web UI ... the second is not updated.
bsublett
Thank you for the assistance! I'm poking around the AV login, but I don't see anything in here for TLS. I must really be missing something--is there just not a way to disable it at this time, not even via the CLI?
