gpaolo
Aug 09, 2015Luminary
Upgrade to 6.2.4 for very early 314 hardware
Hello, I own a ReadyNAS 314 form the beta test program, so it has one of the earliest HW. When I upgraded to 6.2.0, I had a compatibility issue and the NAS stopped working, but it was brilliantly so...
- Aug 09, 2015
Hi gpaolo,
I am sorry to hear that you had a small hiccup after updating the device Firmware to 6.2.0. It is safe to update the firmware and best way to do it is to update it manually. Download the latest Firmware here and upload the file in the admin page under System Tab -> Settings -> Update.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
BrianL2
Aug 09, 2015NETGEAR Employee Retired
Hi gpaolo,
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
- gpaoloAug 09, 2015Luminary
Thank you Brian! Don't worry, the only thing I remember from the previous update was the impressive (and honestly quite unique in my experience!) support I had from the Netgear people here on the forum.
I will proceed with the update, thanks!
- BrianL2Aug 09, 2015NETGEAR Employee Retired
Hi gpaolo,
Great! Hope everything turns out well.
Kind regards,
BrianL
NETGEAR Community- mdgm-ntgrAug 09, 2015NETGEAR Employee Retired
I can't remember what the issue was when you updated to 6.2.0 but it was one we fixed in 6.2.1 and it wasn't due to using beta hardware.
The updated to 6.2.4 should work fine.
