Steve_46
May 14, 2012Aspirant
Upgrade to Ultra 4 Plus, Max storage capacity
I currently have the Ultra 2 Plus with two 2TB Hitachi HDD's and am happy to report that with the help of the excellent support I received from this forum I have it running without issue. I am conside...
May 19, 2012Guru - Experienced User
I only use the built-in admin account. I cannot see the admin home share from FrontView at all, I can only access it from windows explorer.
mdgm wrote: Not a mistake IMO.
You can go to Security > User & Group Accounts > Preferences and enable/disable private home shares. Private home shares are accessible by the user and the "admin" (Frontview) user only.
So if I used it, I wouldn't be able to fix up permissions, etc. via Frontview. That is what I think is a mistake.
- Sep 02, 2016Retired_Member
