Chrisdk
Oct 17, 2013Aspirant
Upgrade with 3TB disk
Hi all I have a ReadyNas Duo v2 with a 1 tb disk. I have purchased a 3 TB disk to expand storage. Data protection is not that important to me, and ideally I would like 4 TB of storage. My nas is...
Oct 17, 2013Guru - Experienced User
When you install the second disk, you will still have 1 TB of storage.
To do what you want, you need to change over to flexraid, and set up each disk as its own data volume (e.g, "jbod", or 2 RAID-0 single disk volumes).
This will require you to do a factory reset, which will destroy your data, and also will require you to reinstall any add-ons, and reconfigure the NAS. After the reset, you have a 5-10 minute window to tell the v2 to use flexraid - you do that with the RAIDar application on the PC.
BTW, many people are quite shocked to discover that their "v2" is actually a v1. You might check this guide: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
If you really have a v1, you won't be able to use the 3TB drive in it at all.
