mickle026
Oct 13, 2015Aspirant
Upgraded to firm 6.4.0 suffers disconnect from network after large data transfers (RN104)
So far I love my NAS, but the other day it wanted to upgrade so I did that. Now when i transfer 20GB+ of files to it or from it, it goes and becomes uncontactable. It still has the ip's connecte...
BrianL2
Oct 17, 2015NETGEAR Employee Retired
Hi mickle026,
Thanks for providing feedback. I suggest that you continue to monitor the ReadyNAS while its connected to your network doing its normal tasks. With regard on how to use iSCSI (LUN), you can the ff. articles.
How do I configure an iSCSI initiator on my ReadyNAS OS 6 storage system?
How do I add an iSCSI Initiator on my ReadyNAS OS 6 storage system?
Let me know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
xupaaki
Oct 17, 2015Tutor
Im having same problemas since 6.4 update (rn102). When I transfer files that all together are large the drive disconnects and the only solution is remove the plug. Doenst metter if using SMB or just downloading files using transmission....if the transfer is longer then a few minutes its almost certain the NAS will stop responding.
I already did 3 factory resets but problem persists
- BrianL2Oct 18, 2015NETGEAR Employee Retired
Hi xupaaki,
Are there any other activities or services running while files are being transferred? Kindly attach the device logs so we can have a further look.
Kind regards,
BrianL
NETGEAR Community Team- xupaakiOct 20, 2015Tutor
sometimes I have transmission running, sometimes I just hadn´t anything else running...
by the way, even transmission can't complete downloading files without the NAS hang a lot of times
Sorry for the noob question, but how do I do to attach logs? I can´t find any option on the forum todo that
- StephenBOct 20, 2015Guru - Experienced User
Best way is to email them. http://kb.netgear.com/app/answers/detail/a_id/21543/~/how-do-i-send-all-logs-to-a-readynas-forum-moderator%3F
