AJL_Electronics
Feb 05, 2015Aspirant
Upgrading from Duo V1 to an RN102
Having had more problems than you can shake a stick at, I have ordered a pair of WD 3Tb Red drives and an RN102 NAS. Am I able to just pull the drives out of my Duo and expect them to work immediately...
mdgm-ntgr
Feb 05, 2015NETGEAR Employee Retired
The RAID for at is different. You will need to copy your data across your network.
Do you have a backup?
The whole point of a factory reset is to wipe the disks, create the partitions, format them, install the OS onto the disks etc. Trying to do a factory default with the disks removed achieves nothing.
