AJL_Electronics
Feb 05, 2015Aspirant
Upgrading from Duo V1 to an RN102
Having had more problems than you can shake a stick at, I have ordered a pair of WD 3Tb Red drives and an RN102 NAS. Am I able to just pull the drives out of my Duo and expect them to work immediately...
Feb 05, 2015Guru - Experienced User
mdgm's point is that you literally can't factory reset the v1 with no disks installed. "factory reset" means "do a fresh factory install on the disks". With no disks, it cannot be done.
If you can't access the NAS at all, then you could try powering it down, connecting disk 1 to a PC with SATA or a USB adapter. Linux Reader (http://www.diskinternals.com/linux-reader/) is a free software package that you can use to copy the data off. You could also try Netgear's paid support (support.netgear.com).
