Amit200465
Oct 06, 2013Aspirant
Upgrading HD from 2TB to 3TB
I am using ReadyNAS Ultra 6 [X-RAID2] Firmware: RAIDiator 4.2.24 with six 2TB hard disk installed. As I am running short of space I upgraded one of the the HD to 3 TB. After resync the system is show...
mdgm-ntgr
Oct 06, 2013NETGEAR Employee Retired
If you were using dual-redundancy Frontview would have said so.
Yes, your volume capacity indicates that you are using single-redundancy. So after replacing one more 2TB HDD with a 3TB one there will be a resync and then vertical expansion should take place. You may need to reboot once or twice before vertical expansion takes place. Wait 5-10 minutes between each reboot.
