BJB
Jan 19, 2016Aspirant
Upgrading my RN104 from 6.1.9
Greetings. I received some great advice on another thread but that was quite a while ago and it is closed. And I am just now finally getting around to this upgrade. My RN104 is on version 6.1.9...
- Jan 25, 2016
This is done.
Thanks,
BJB
JennC
Jan 19, 2016NETGEAR Employee Retired
Hello BJB,
Before updating to 6.4.1, please read this article: ReadyNAS OS 6.4.1: FAQ on Maintenance Firmware Release.
Factory Reset will delete all files and settings you have on the NAS. OS reinstall won't. See the boot menu's options descriptions here.
You need to have 6.2.5 before updating to 6.4.0, and you need 6.4.0 before updating to 6.4.1.
BJB
Thanks. What about my question about running maintenance?
- BJBJan 19, 2016Aspirant
I tried to edit the above but could not...
I do see that when I drilled down a few links, I found a link on maintenance. I am running in mirror mode with 4 discs.
It appears that a lot hinges on whether I have "bitrot" turned on. This also seems to depend on OS and device. I am running 6.1.9 on an RN104 and AFAIK at defaults. Do I need to scrub?
It appears that balancing and defrag are advisable regardless.
Snapshots....again running at defaults. I remember trying to figure out how to identify and delete snapshots and there were issues with some firmware versions and snapshots and I basically gave up. What should I do with snapshots before upgrading. The maintenance document explains what they are but does not really recommend what to do.
Thanks,
BJB- StephenBJan 19, 2016Guru - Experienced User
I run all the maintenance checks quarterly (which defrags and balances less frequently than mdgm's suggestion). I also leave bit-rot protection on (even though I am not running RAID). Scrub acts as a good disk diagnostic (reading and verifying all files), so I think that is worth doing - even if errors can't be fixed, I want to know they are happening, so I can restore from backup.
For snapshots, the first question is whether they are appropriate for the share in the first place. If the files are frequently modified (a torrent folder, or an sql database, ...) then you are better off turning snapshots off altogether. In general my shares don't have a lot of files like that, so I leave snapshots on,
While Netgear does "thin" the snapshots over time, they won't deletely the automatic monthly ones. IMO that's a huge mistake on their part - they should have a retention setting. Once a month I go in, and delete the oldest snapshot in each share - keeping the oldest snapshot at 3 months old. Your idea of the right threshold might be different, but I do suggest you go in monthly and delete snapshots older than your threshold.
Start by figuring out how far back seems reasonable/useful to you. If the space is excessive, then you might need to adjust your threshold, but treat that as a second step. 6.4.x gives more useful information on snapshot use than what you have now.
Thanks very much for these tips on maintenance and helpful analysis.
BJB
