BJB
Jan 19, 2016Aspirant
Upgrading my RN104 from 6.1.9
Greetings. I received some great advice on another thread but that was quite a while ago and it is closed. And I am just now finally getting around to this upgrade. My RN104 is on version 6.1.9...
- Jan 25, 2016
This is done.
Thanks,
BJB
mdgm-ntgr
Jan 19, 2016NETGEAR Employee Retired
JennC wrote:
You need to have 6.2.5 before updating to 6.4.0, and you need 6.4.0 before updating to 6.4.1.
You can update direct from 6.2.5 to any 6.4.x firmware. You don't need to go via 6.4.0.
If your volume usage is below about 80-85% you could start by running a balance after you update to 6.2.5.
BJB, please send me your logs (see the Sending Logs link in my sig). You could download the logs both before and after updating to 6.2.5.
BJB
Logs are sent per your sig sending logs link.
Thanks,
BJB
