carpii
Dec 10, 2014Tutor
Upgrading NVX disk to Pro 4 OS6 ?
Ive just got a Pro 4, which Ive been informed uses ReadyNas OS 6 I've loaded it with disks from my old NVX and its booting up ok, and providing Frontview/Raidiator 4 Just a couple of questions.. ...
Danthem
Dec 10, 2014NETGEAR Employee Retired
Hello Carpi,
Pro 4 does not by default run OS 6 - are you sure it's a Pro 4 you got and not a 314? They should be hard to get from a reseller nowadays.
There are ways to get OS 6 on a Pro device but it is not officially supported and you will be denied support, I'm sure you can find guides for it here on the forum.
