carpii
Dec 10, 2014Tutor
Upgrading NVX disk to Pro 4 OS6 ?
Ive just got a Pro 4, which Ive been informed uses ReadyNas OS 6 I've loaded it with disks from my old NVX and its booting up ok, and providing Frontview/Raidiator 4 Just a couple of questions.. ...
vandermerwe
Dec 10, 2014Master
Are you going to be using this device to hold the primary data? If so I would stick with Raidiator OS 4, the latest version of it is 4.2.27, available here:
http://kb.netgear.com/app/answers/detai ... /related/1
You also presumably have some warranty left, another reason not to change to OS 6.
If you want to read a bit more about putting OS 6 onto legacy devices, then start here:
viewtopic.php?f=160&t=70133
