IanLinwood
Nov 17, 2016Aspirant
Upgrading (replacing) healthy disks with newer, faster disks
I have a RN102 with 2x4GB disks in x-raid. These disks are WD Green @5400RPM. I have Purchased x2 4GB WD RED @7200RPM. What is best practice for replacing these disks? Do I power off, replac...
- Nov 18, 2016
StephenB wrote:
There is no need to turn off the NAS, it is fine to remove disk one with the NAS running, and then hot-insert the replacement. After resync to the same with disk two. Either way, if disk 1 is healthy it will function as a backup copy (you can reboot the NAS with only that disk installed)
File system on hot removed disk can be healthy and can be not. This is lottery. The file system love shutdown. Correct way to get healthy backup copy is to remove disk from turned off NAS.
sotrack
Nov 17, 2016Luminary
1. turn off NAS
2. remove any one disk from NAS. This disk will be your backup copy if something wrong with new disk synchronization
3. turn on NAS with one old disk. Wait system booting.
4. insert new disk into working NAS. Synchronization will be started. Wait for rebuild.
5. After rebilding replace in the working NAS second old disk. Wait for rebuilding.
6 Finish.
- StephenBNov 17, 2016Guru - Experienced User
sotrack wrote:
1. turn off NAS
6 Finish.
There is no need to turn off the NAS, it is fine to remove disk one with the NAS running, and then hot-insert the replacement. After resync to the same with disk two. Either way, if disk 1 is healthy it will function as a backup copy (you can reboot the NAS with only that disk installed).
I agree with Vandermerwe that going with NAS-purposed drives is a good decision. WDC Red drives have essentially the same spindle speed as the greens, WDC Red Pro run at 7200 rpm. The RN102 is limited by its CPU speed, so the WDC Reds are fine. Even in the higher-end NAS, the Reds perform quite well, and run a lot cooler than 7200 rpm drives.
- sotrackNov 18, 2016Luminary
