dunkymole
Feb 03, 2013Aspirant
Upgrading Sparc ReadyNAS Duo to ReadyNAS Ultra 2 Plus
Hi, I have an old duo with a couple of ST31500341AS inside. I decided to updgrad and have a ReadyNAS Ultra 2 Plus on the way in the post. I may have poor searching skills but I didnt find anything li...
vtxrider
Feb 26, 2013Tutor
I have the same issue but am upgrading from a Duo V1 to a NV+ V2. Actually the easiest and fastest way I found was to hook up the NV+ with 2 drives, drag-n-drop all of my folders from the Duo, when done just remove the 2 drives from the Duo and expand the NV+ to 4 drives with them.
