Equinox1
May 29, 2019Guide
Upgrading to 6.10.1
This morning I was prompted to update to 6.10.1, and so i did (from 6.10.0HF2) After the classical double reboot, the unit is stuck in a state where the screen says “Rebooting: upgrading FW” for a ...
- Jun 19, 2019
Hi guys,
Despite the zero intereste or guidance from Netgear members on this forum, I managed to put the Pro 6 back online.
I indeed used the boot menu, with the option “Reinstall OS”; it took ages, but it brought the NAS back to life. Little huge detail: the RAID array had to be synced up once it was back online (and it took an extra 8 hours).
It’s the 3rd OS upgrade that breaks this NAS...
tony359
May 30, 2019Apprentice
I have the same NAS and I am very interested to know what the outcome is. Can I also ask whether 6.10.0 worked ok on your model before you upgraded?
Equinox1
May 31, 2019Guide
The upgrade to 6.10.0 also had hick-ups. But I could connect via SSH and relaunch the upgrade; which didnt happen this time.
The installed and the NAS in general worked fine in 6.10.0, but the "available apps" in the app store became almost non-existent, not really sure why.
- StephenBMay 31, 2019Guru - Experienced User
Does tech support mode work? You could attempt to relaunch the update from there.
- Equinox1May 31, 2019Guide
Hi StephenB,
I was waiting for some more feedback, so I havent tried the tech support mode yet. Since I'm not familiar with it, I'll have to read the friendly manual first. :-)
I'll let the community know, once I put your suggestion to the test.- Equinox1Jun 19, 2019Guide
Hi guys,
