khaos-spawn
Oct 02, 2016Initiate
Upgrading to 6.6.0
Have folks updated the legacy NAS units to 6.6.0? I have 6.5.1 at the moment and am wondering whether it's safe to go ahead with the upgrade.
- Oct 02, 2016
Just done it on 2 ReadyNas Appliances Pro 6 and Ultra 6 both work fine after the upgrade.
I also tested ReadyDR which works fine too
mdgm-ntgr
Oct 02, 2016NETGEAR Employee Retired
We'd suggest following ReadyNAS OS 6: Firmware Upgrade Guide and Tips when doing any firmware update.
If you follow this guide you do minimise your risks.
If you use apps I would suggest checking the threads about app compatibility and updating your already installed compatible apps to the latest version (if you have not done so already) before doing the firmware update.
khaos-spawn
Oct 03, 2016Initiate
Hi All,
Upgraded just fine and updated the apps that I used. One issue I'm noticing is that I'll shut it down, and a short time afterward, it will start back up again. I don't run it 24/7 - it's more on demand, so this is a little odd. Any ideas on troubleshooting?
- mdgm-ntgrOct 03, 2016NETGEAR Employee Retired
That might suggest a PSU that is on the way out. I assume this happens regardless of when or how the system is shutdown? If not the issue is likely something different.
