khaos-spawn
Oct 02, 2016Initiate
Upgrading to 6.6.0
Have folks updated the legacy NAS units to 6.6.0? I have 6.5.1 at the moment and am wondering whether it's safe to go ahead with the upgrade.
- Oct 02, 2016
Just done it on 2 ReadyNas Appliances Pro 6 and Ultra 6 both work fine after the upgrade.
I also tested ReadyDR which works fine too
AMRivlin
Oct 09, 2016Apprentice
Upgraded a pro 6 to 6.6.0 but the web gui doesn't load. :(
Low and behold IP was changed to dynamic from my static setting.
mdgm-ntgr
Oct 09, 2016NETGEAR Employee Retired
So do you get the management service is offline error or was it just the I.P. change that was the problem?
- AMRivlinOct 10, 2016Apprentice
Just the IP change threw me off, I tried rebooting 3x, finally looked at the LED on the Pro6 and it said .177 (vs my selected static .100)
I then was able to login/etc.
Was still having problems, just noticed I cant get static to stick in the GUI. Keeps reverting to DHCP. Annoying.
- mdgm-ntgrOct 11, 2016NETGEAR Employee Retired
Do you still this after clearing your web browser cache?
If so, can you send me your logs (see the Sending Logs link in my sig)?
