khaos-spawn
Oct 02, 2016Initiate
Upgrading to 6.6.0
Have folks updated the legacy NAS units to 6.6.0? I have 6.5.1 at the moment and am wondering whether it's safe to go ahead with the upgrade.
- Oct 02, 2016
Just done it on 2 ReadyNas Appliances Pro 6 and Ultra 6 both work fine after the upgrade.
I also tested ReadyDR which works fine too
mdgm-ntgr
Oct 09, 2016NETGEAR Employee Retired
AMRivlin wrote:
Upgraded a pro 6 to 6.6.0 but the web gui doesn't load. :(
Low and behold IP was changed to dynamic from my static setting.
So do you get the management service is offline error or was it just the I.P. change that was the problem?
AMRivlin
Oct 10, 2016Apprentice
Just the IP change threw me off, I tried rebooting 3x, finally looked at the LED on the Pro6 and it said .177 (vs my selected static .100)
I then was able to login/etc.
- AMRivlinOct 10, 2016Apprentice
Was still having problems, just noticed I cant get static to stick in the GUI. Keeps reverting to DHCP. Annoying.
