khaos-spawn
Oct 02, 2016Initiate
Upgrading to 6.6.0
Have folks updated the legacy NAS units to 6.6.0? I have 6.5.1 at the moment and am wondering whether it's safe to go ahead with the upgrade.
- Oct 02, 2016
Just done it on 2 ReadyNas Appliances Pro 6 and Ultra 6 both work fine after the upgrade.
I also tested ReadyDR which works fine too
Skywalker
Oct 11, 2016NETGEAR Expert
AMRivlin, can you enable Secure Diagnostic Mode, and PM me the 5-digit code? Your logs show a permissions issue with the directory where the network config file lives. Side note: your logs also show what appears to be a brute-force attack on the SSH server. You may want to remove the NAS from direct internet access, or at least disable password authentication and require keys instead.
AMRivlin
Oct 11, 2016Apprentice
Thanks, sent. Was the brute force recent?
