Cliff_MI
Jul 17, 2015Guide
UPS Communication
Has anyone has recent issues with UPS communications? I have two ReadyNAS PRO 2 and they suddenly starting having UPS communication issues. One of them has the UPS master and broadcast UPS status....
JennC
Jul 22, 2015NETGEAR Employee Retired
Hello Cliff_MI,
Since your ReadyNAS Pro 2 is running an OS6 firmware. Please try disabling the Antivirus and see if same error. Then enable it again then continue to check if you get the same error.
Cliff_MI
Sep 11, 2015Guide
I will try that, funny that would cause an issue. It just started when I updated to 6.2.4
I am using a cyberpower 625VA UPS with USB connection to the NAS.
I have hooked it up to another brand NAS and getting info off from it.
I have not gotten any error messages on the new NAS controling it, but continue to get error messages.
Failure to communicate with UPS and then 5 sec later saying that it is working again.
This goes on every few hours.
I got so tired of the issue that I deleted the UPS off of the NAS.
I will re connect and see if it changes.
Cliff
