tonymazz31
Jan 20, 2025Aspirant
USB drive no longer recognised
I have been connecting the same external USB drive to my ReadyNAS to perform backups and now after the latest firmware update to 6.10.10 it is now no longer recognised. This now makes it impossible f...
- Jan 31, 2025
tonymazz31 wrote:admin@yallara:~$ df / -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 4.0G 0 100% /
Yes, this is the problem - a completely full OS partition.
Do you know how to find the largest files?
You can try moving into the top level folders - for instance cd /var
Then try this: du -hsx * | sort -rh | head -10
Jan 21, 2025Guru - Experienced User
tonymazz31 wrote:
I would appreciate that support look into this instead of suggesting that I purchase a new NAS.
Support is no longer available, and it's been a long time since Netgear responded to a post here. They wouldn't tell you to purchase a new ReadyNAS, since there are none. The most recent ReadyNAS platforms were launched in 2017.
- What model NAS do you own?
- Have you tried all the USB ports on the NAS?
- How are you formatting the drives?
