jds90
Feb 23, 2025Tutor
usb flash recovery 4.1.8.img
bought a second hand readynas duo rnd2000 v2, using RAIDar its found on my network, see' both seagate 500gb, but its saying corrupt root, wher can i find this....thanks in advance Joe
- Feb 27, 2025
jds90 wrote:
the nas sees the 80gb, its recognized when i hit the disk icon but also says corrupt root , the nas also sees both hard drives and displays them also when i hit the disk icons but stills says corrupt root.
Did you try doing a factory reset using the boot menu? This is done with the disks installed:
- Power off your system.
- Using a straightened paper clip, press and hold the Reset button.
- Press and release the Power button to power on the system.
- To perform a factory reset, continue to hold the Reset button until all Disk LEDs flash twice (once at 5 seconds and then 25 seconds later), and then release the button.
Make sure you hold the reset button down long enough on step 4.
The reset button is recessed and is on the rear panel:
Feb 24, 2025Guru - Experienced User
jds90 wrote:
hi thanks for your reply RAIDar says no disks detected....joe
What happens if you power down the NAS, put the 80 GB drive back in, and then power up?
jds90
Feb 26, 2025Tutor
sorry i meant corrupt root
- StephenBFeb 26, 2025Guru - Experienced User
So the NAS is detecting the 80 GB drive but not the two 500 GB seagates????
- jds90Feb 27, 2025Tutor
the nas sees the 80gb, its recognized when i hit the disk icon but also says corrupt root , the nas also sees both hard drives and displays them also when i hit the disk icons but stills says corrupt root. i have tried powering down and putting 1 500 in and powering on but still get corrupt root, did the same for the other 500 and got the same message....lost my brother a little while ago through motor neuron disease, i have his pc and going to try the 1tb drive that's in it, will keep you updated.....joe
- StephenBFeb 27, 2025Guru - Experienced User
