JohnnyR2D2
Feb 24, 2017Guide
USB Formatting Capacity Limit
Hello guys,
Quick help pls?
Running OS 6.1.1
1 - I have a USB 3.0 to SATA Dual-Bay USB 3.0 Hard Drive Docking Station attached to my NAS which was previously with two 3TB disks and now that I remove one of the 4TB from the NAS and replace it by an 8TB I want to "upgrade" the docking and replace one of the 3TB by the 4TB disk I have removed from the NAS. I did that already and after formatted using the Frontview NFTS option, it only shows 2TB as a maximum capacity. It only shows the full capacity (3.6TB) If I chose to format it on my PC before and then plug it in the docking station.
2 - Tried Ext3 and Ext4 and even less capacity is showing (512 MB)
3 - Based on the above should I then format it in Windows before plug it or is there anything I'm missing?
4 - Last but not least does anyone knows if Netgear is planning to allows us to change the USB drives names?Right now is always USB_HDD_2, USB_HDD_3 and so on.
Thanks,
Joao
- FramerVNETGEAR Employee Retired
Hi JohnnyR2D2,
So just to confirm, the 4TB drive is only showing 2TB?
Please try formatting it on a Windows PC as well.
As for the USB naming, I think it is still being checked if it can be added as a feature.
That is correct. If I format the disk using Frontview and chose NFTS it will show only 2TB. If I format and chose Ext4 or Ext3 things get even worse and it shows only 512KB or MB (can't remember really)
That's what I did and when I do that it works perfectlly and shows the full capacity 3.64TB
That suggests there's a bug in the NAS formatting.
