ilneill
Oct 19, 2015Apprentice
USB HDD problems - linked to recent FW6.4.0 upgrade?
I have a RN102 - 2x 2TB discs. In the past few days I have had trouble with my backups to sever USB hdds - several as I swap them trying to resolve the issue. I am not at the point where the ...
- Dec 07, 2015
Hi,
Just reporting back, so as to complete this thread...
I have updated my RN102 to v6.4.1, and retested the portable USB drive that was troublesome with v6.4.0. It looks like, whatever the problem was, it has been resolved and I have successfully completed a full backup (via RSYNC) to this drive.
Ian
ilneill
Hi BrianL
Thankyou for taking the time to reply.
I am aware of the USB drive name change issue... until I had this possible hardware issue, I was up to USB_HDD_4 with the same drive. I had been incrementing my rsync back up job each time :-)
I have done more testing. I have now attached a desktop USB HDD, with its own power supply, and It has been recognised and mounted immediately. The previous 2 USB HDDs were of the portable type, power from the RN102.
I am re-running my backup job as I type this... well, it has been running all night so far and still has a lot to do.
So, has something changed that would affect my RN102's ability to power USB ports? I have identical drives on 3 RN Duo's, now for 12mths +, and the RN102 has had one since I bought it 7 months ago.
Kind regards,
Ian
ilneill
Oct 20, 2015Apprentice
Ok. An update.
Using a desktop USB HDD (with own PSU), my backup has completed without a hitch... no errors, no admin page unresponsiveness. It just worked.
So, it looks like the bus powering of my previous portable USB HDDs is the issue...
I just have no idea why the RN102 suddenly became unable to power my portable USB HDD after 7 months, and after upgrading to OS6.4.0 (coincidence?)
Any advice appreciated.
Ian
- BrianL2Oct 20, 2015NETGEAR Employee Retired
Hi ilneill,
Thanks again for the update. If you have contacted support team regarding this issue, it would be best if you will give them this information.
Kind regards,
BrianL
NETGEAR Community Team- ilneillOct 20, 2015Apprentice
Hi BrianL
Yes it does seem to be the case. I have no access troubles and my RSYNC backups work if I use a USB HDD that has its own power supply. If I use either of the portable bus powered USB HDDs that I happen to have then I have trouble with the RN102 recognising them, with the RN102 seeming to get "stuck" and becoming unresponsive until I disconnect them. If it does manage to recognise the drive, the backups fail at some point with timeout errors.
One of the USB HDDs was attached to the RN102 for 7 months, and the other was until recently attached to a RN Duo (until I upgraded to a larger one).
This does seem to be related to the bus powering of the USB HDDs, but I accept that my testing is hardly exaustive. Additionally, I am only linking my issue to the OS6.4.0 software simply because upgrading to that was the last thing I changed in my otherwise stable setup.
I will contact support as you have suggested.
King regards,
Ian
- BrianL2Oct 21, 2015NETGEAR Employee Retired
Hi ilneill,
Just keep us posted here by updating this thread on what happens.
Kind regards,
BrianL
