TehDags
Jul 31, 2019Tutor
USB Recovery
Model: RNRX4410-100NAS (2100) Looking for the process to boot this particular model to the USB for reccovery. Before posting links, please make sure it has the information. I've looked over a...
- Aug 05, 2019
Hopefully this will help more people. Even though this model is a rackmount. The reset button will only boot you to the boot menu. The "Backup" button is the button you want even though it has a reset button. Holding the backup button at power on for 10-15 seconds will cause it to boot to the USB.
Marc_V
Aug 01, 2019NETGEAR Employee Retired
Welcome to the Community!
You can use https://kb.netgear.com/30267/RAIDiator-4-2-USB-Recovery-Tool. All the information you need and what to look out for is mentioned on this KB article
Since your ReadyNAS 2100 is a rackmount type unit, you will have to check and rely on your USB device LED indicator to be notified that the USB Recovery process has started since these units does not have VGA ports. You just need to press the Reset button for 15 seconds and the USB recovery should start automatically unless there is an issue with the USB or the Chassis, your unit will then automatically shutdown and that indicates that the USB recovery has been successful.
Please do note that if the unit did not shutdown few minutes after booting it on USB Recovery mode then the recovery process has failed and you might need to try a different set of USB so you may need to prepare a few USB drives in advance.
HTH
Regards
Sandshark
Aug 01, 2019Sensei
So if this process is done on a rackmount unit without a VGA connection, there is no indication using the NAS LEDs? You must rely on the USB device's access LED (assuming it is even equipped with one) to let you know anything is happeneing? I can say nothing more than "poor design" and hope the user the best in performing this operation.
I do wonder, however, what drives the decision to do a USB recovery. It's typically a last resort fix and can make things worse when done under the wrong circumstances..
