Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
IanSav
Jun 11, 2007Apprentice
Hi Greg,
If you are able to verify the error and subsequently fix it with your SAMBA tests then please let us all know. Perhaps the fix may be compatible with Infrant's needs and can thus be implemented for all of us. The alternative could be that you can tell HP what they are doing wrong and then they can fix their firmware, again we all benefit.
Thanks for investigating this.
Ian.
Ian.
