Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
renato1
Jun 28, 2007Aspirant
Hello,
I am wondering if I experience the same problem with my Officejet 7780.
When I ry to scan directly to my ReadyNas NV+, it starts to write the file to the selected directory, but after creating the file (a 8KB file size IS created), the systems halts. The OfficeJet never ends its scanning action, the file does not grow.
I am pretty confident the user/passwd setting is correct (as the file IS created)......
Grtz,
R.
Grtz,
R.
