Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
IanSav
Jul 03, 2007Apprentice
Hi Skywalker,
Thank you for the plugin. It took me a few goes before my NV+ would accept the plugin (IE browser kept reporting page not found) but it did eventually take and the plugin installed.
The good news is I can now authenticate my HP OfficeJet 9130 to my ReadyNAS NV+. The bad news is I now get a network error trying to transfer a scan to the ReadyNAS. Here is the samba log of my two attempts:
[2007/07/04 10:07:31, 0] smbd/server.c:main(805)
smbd version 3.0.22 started.
Copyright Andrew Tridgell and the Samba Team 1992-2006
[2007/07/04 10:09:52, 2] auth/auth.c:check_ntlm_password(307)
check_ntlm_password: authentication for user [xxxxxxxx] -> [xxxxxxxx] -> [xxxxxxxx] succeeded
[2007/07/04 10:10:05, 0] smbd/reply.c:reply_write_and_X(3057)
write_andX: End of header assumed at 64 but was at 59.
[2007/07/04 10:10:05, 0] smbd/reply.c:reply_write_and_X(3061)
write_andX: SMB headerlength of 59. Fall back to regular write reading 408 bytes
write_andX: SMB headerlength of 59. Fall back to regular write reading 1392 bytes
[2007/07/04 10:10:35, 0] lib/util_sock.c:receive_smb_header_raw(807)
Packet read error. Expected 110981 bytes but received 0.
[2007/07/04 10:11:12, 2] auth/auth.c:check_ntlm_password(307)
[2007/07/04 10:11:20, 0] smbd/reply.c:reply_write_and_X(3057)
[2007/07/04 10:11:20, 0] smbd/reply.c:reply_write_and_X(3061)
[2007/07/04 10:11:50, 0] lib/util_sock.c:receive_smb_header_raw(807)
Packet read error. Expected 10336 bytes but received 0.
Even though the logs say that 0 bytes were transferred I do get a file created for each scan attempt with about 6KB of data. The data does look like the beginning of a valid PDF file. (This is now starting to sound like the other problem with the 7xxx series units.)
Is there anything else I can do to help you identify the issue?
Ian.
Ian.
