Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
IanSav
Jul 03, 2007Apprentice
Hi Skywalker,
Well either I or my NAS is now confused.
After I installed the new patch the first time I was told that the option was enabled but my OfficeJet wouldn't connect (like the original error) so I installed the option again and it now says that the option is disabled but I can connect again. It looks like the enable/disable message is reversed.
I am still unable to achieve a proper scan. I get about 6KB of the PDF and the OfficeJet reports a network error. (This is the same as before.)
smbd version 3.0.22 started.
Copyright Andrew Tridgell and the Samba Team 1992-2006
[2007/07/04 11:38:08, 2] auth/auth.c:check_ntlm_password(307)
check_ntlm_password: authentication for user [xxxxxxxx] -> [xxxxxxxx] -> [xxxxxxxx] succeeded
[2007/07/04 11:38:17, 0] smbd/reply.c:reply_write_and_X(3057)
write_andX: End of header assumed at 64 but was at 59.
[2007/07/04 11:38:17, 0] smbd/reply.c:reply_write_and_X(3061)
write_andX: SMB headerlength of 59. Fall back to regular write reading 408 bytes
write_andX: SMB headerlength of 59. Fall back to regular write reading 1392 bytes
[2007/07/04 11:38:48, 0] lib/util_sock.c:receive_smb_header_raw(807)
Packet read error. Expected 128191 bytes but received 0.
[2007/07/04 11:39:27, 2] auth/auth.c:check_ntlm_password(307)
[2007/07/04 11:39:34, 0] smbd/reply.c:reply_write_and_X(3057)
[2007/07/04 11:39:34, 0] smbd/reply.c:reply_write_and_X(3061)
[2007/07/04 11:40:05, 0] lib/util_sock.c:receive_smb_header_raw(807)
Packet read error. Expected 126003 bytes but received 0.
[2007/07/04 11:42:02, 2] auth/auth.c:check_ntlm_password(307)
Anything else I can try for you?
Ian.
Ian.
