Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
IanSav
Jul 16, 2007Apprentice
Hi Skywalker,
Trust HP to make this difficult. ;)
I will try to add the SPNEGO patch one more time and see what happens...
Edit: No go :(
The logs show that I can once again login but I now get the old data transfer error.
smbd version 3.0.22 started.
Copyright Andrew Tridgell and the Samba Team 1992-2006
[2007/07/17 16:32:09, 2] auth/auth.c:check_ntlm_password(307)
check_ntlm_password: authentication for user [iansav] -> [xxxxxxxx] -> [xxxxxxxx] succeeded
[2007/07/17 16:32:32, 0] smbd/reply.c:reply_write_and_X(3057)
write_andX: End of header assumed at 64 but was at 59.
[2007/07/17 16:32:32, 0] smbd/reply.c:reply_write_and_X(3061)
write_andX: SMB headerlength of 59. Fall back to regular write reading 408 bytes
write_andX: SMB headerlength of 59. Fall back to regular write reading 1392 bytes
[2007/07/17 16:33:02, 0] lib/util_sock.c:receive_smb_header_raw(807)
Packet read error. Expected 81863 bytes but received 0.
What should I try next?
Ian.
Skywalker wrote:
IanSav wrote: Should I be using both patches or just the latest patch? Is the SPNEGO patch incorporated into this patch? When the SPNEGO patch was enabled I could login with the scanner but file writes failed.
Well, the SPNEGO patch should have been incorporated with this one, but it's being done on a client architecture basis, instead of a global basis. Perhaps the SPNEGO happens too early for the patch to work (before figuring out the client architecture). You can install the last addon (ToggleSPNEGO) once more to see if that helps. That will disable it globally. Sounds like HP fixed the bug in the 7780, but not the 9130...
Edit: No go :(
Ian.
