Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
jarrah
Dec 19, 2007Aspirant
Hi Ian,
Just in case you were wondering, I still can't scan after installing 4.00c1-p2. Here are the log messages:
[2007/12/16 08:48:05, 0] smbd/server.c:main(944)
smbd version 3.0.25b started.
Copyright Andrew Tridgell and the Samba Team 1992-2007
[2007/12/19 13:02:18, 0] smbd/server.c:main(944)
[2007/12/19 15:21:09, 2] auth/auth.c:check_ntlm_password(309)
check_ntlm_password: authentication for user [greg] -> [greg] -> [greg] succeeded
[2007/12/19 15:21:31, 0] smbd/reply.c:reply_write_and_X(3116)
write_andX: (OS 8) End of header assumed at 64 but was at 59.
[2007/12/19 15:21:31, 0] smbd/reply.c:reply_write_and_X(3120)
write_andX: SMB headerlength of 59. Fall back to regular write reading 1392 bytes
[2007/12/19 15:21:31, 0] smbd/reply.c:reply_special(362)
Unexpected session response
[2007/12/19 15:21:34, 0] lib/util_sock.c:receive_smb_header_raw(811)
Packet read error. Expected 12141 bytes but received 0.
Greg
Greg
