Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
brianadkins
Jun 03, 2008Tutor
Okay, we got a 7780 in today, and I may have a solution. You can try this addon out. It should fix both of those issues. DawgDaze (and anyone else in Share security mode), you'll need to use the share name as the user name in the OfficeJet setup. If you don't have a password set on the share, just leave the password field empty.
OK so I bought an HP 7780 today and was pulling my hair out trying to get the scan to ReadyNAS working without luck... I should have known that Infrant (ok.....netgear) would be able to provide support on this HP problem that was superior to HP's own support.
By the way, I am currently on RAIDiator 4.01c1-p1 [1.00a041] and the tip above about using the share name as the HP User Name was apparently the key to my woes... just got my first usable scan without a PC involved.
Thanks, guys.
-Brian
