Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
ewok
May 11, 2009NETGEAR Expert
Yacht_Rocked wrote:
I didn't because it works fine scanning to a Vista PC and to a new Mac, so my assumption was that it was a ReadyNAS SMB issue and not an HP one.
By the same token, if your Vista PC and Mac can access the ReadyNAS over CIFS without any problems, then my assumption would be that it's an HP problem. :D
Really though, being that we don't have access to the inner workings of the OfficeJet hardware/firmware/drivers, there may not be much we can do. If HP can at least tell us why the device is just hanging rather than gracefully recovering or showing some kind of error message, then we can look into it. As it is now, it's just a mysterious device that just hangs for some reason.
Yacht_Rocked wrote:
Given the above, would you still like me to contact HP then? I'm certainly willing to do so.
I think that would be a good idea. I found this on the HP support forums with a similar problem (almost exactly the same actually, is that you?):
http://h30434.www3.hp.com/psg/board/mes ... ge.id=2361
No responses though. :roll:
