Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
Yacht_Rocked
May 11, 2009Aspirant
Hi, Good find on the HP forum. Negative, it's not me who posted on that HP forum. But I'm glad to see others having the problem, in a way, because it confirms that it's not just a one-off issue. I will open a ticket with them. I don't look forward to working up thru all the support tiers, but I'm not seeing any other way to solve the problem. Thank you for clarifying your thoughts and giving me the "why" of why Netgear said they can't support the scan-to-network feature of this printer, or, as you have stated more accurately, you cannot diagnose the printer issue from your side of the problem and it's really an HP issue. Thanks again, and I hope to return with better news.
Here's copy of ticket I've opened with HP:
E-mail form
Thank you for contacting HP e-mail support
Thank you for submitting your e-mail to Hewlett-Packard's Customer Care. You should receive a system generated acknowledgement within [[time frame, may vary by region]]. If you do not, please re-submit taking extra care to verify that you are entering a valid and functional e-mail address.
If you have additional feedback or enquiries, please Contact HP
When did you purchase your product? : April2009
Product HP Officejet Pro 8500 Wireless All-in-One Printer - A909g
Select a problem area: scanning/copying/faxing
What is your serial number (SN): <redacted>
What is your operating system?: Microsoft Windows Vista Business 32
How is your product connected to your PC? Network
If there is an error message, please specify:
Problem Description:
Will not scan to NETGEAR ReadyNAS (model is Duo), Netgear support says it is HP issue. It does scan to Vista PC and Mac fine. It is able to sign onto NAS using share username and password, but locks up after writing about 16-17K of the scan output file. At that point, printer must be rebooted.
Please provide previous troubleshooting steps, or information that can help HP assist you.:
SMB log from ReadyNAS says: [2009/05/11 10:39:02, 2] auth/auth.c:check_ntlm_password(309) check_ntlm_password: authentication for user [jon0] -> [jon0] -> [jon0] succeeded [2009/05/11 10:39:35, 0] smbd/reply.c:reply_write_and_X(3118) write_andX: (OS 8) End of header assumed at 64 but was at 59. [2009/05/11 10:39:35, 0] smbd/reply.c:reply_write_and_X(3122) write_andX: SMB headerlength of 59. Fall back to regular write reading 5724 bytes
Other Readynas users are also experiencing this exact issue, see:
viewtopic.php?f=23&t=7809&p=159944#p159944
viewtopic.php?f=24&t=28558
viewtopic.php?f=24&t=28120
http://h30434.www3.hp.com/psg/board/mes ... ge.id=2361
Need HP to look closely at this issue as ReadyNAS devices are growing in popularity quickly and many users are starting to experience this issue.
Has anything changed since the unit functioned properly (installation of SW, settings, cabling, etc.):
The unit has never been able to scan to the ReadyNAS device. Again, it does scan to PC and Mac fine. And of course, the Vista PC and Mac can access the ReadyNAS over CIFS without any problems.
How would you describe your technical skill level?: Advanced
First Name Jon
Last Name <redacted>
Phone Number <redacted>
Email Address <redacted>
E-mail form
First Name Jon
