Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
gPAQ
Jul 18, 2009Aspirant
laburton wrote: After 2 years of struggling with HP support and uncountable internet searches thru forums, etc trying to find the work around to allow the "Digital Filing" feature of my HP L7780 to work correctly with my NetGear ReadyNAS NV+, I finally came across this forum thread about using the share name as the user name when setting up the directory info for the scan. Presto! Works like a charm! I am incredibly indebted to the techs who have diligently worked thru all of this and developed the solution. HP support was non existent.
Sounds promising... Do you care to share the details or a link to the thread you are referring to? To the best of my knowledge, the ReadyNAS does not accept a share with the same name as an existing username. Any help and tips appreciated!
