Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
miltonabove
Jul 19, 2009Aspirant
Arghh! Too frustrating. I have spent the last several hours trying to get my new HP 8500 all-in-one to scan to my ReadyNAS Duo, but no luck. Works great saving to a network folder on my Vista machine. Initially I had the 17k file freeze issue mentioned by several others. Then I tried the new 4.1.6 firmware, using the above posts suggestion of using the share name as the user name on the HP software, still no luck. Now I can't pass the HP software's network test: keeps saying invalid username/password. Would love to hear if anyone else is successful. ReadyNAS symbd.log shows this every time:
[2009/07/19 20:54:49, 1] auth/auth_sam.c:sam_account_ok(142)
sam_account_ok: Account for user 'scan' was disabled.
[2009/07/19 20:54:49, 2] auth/auth.c:check_ntlm_password(319)
check_ntlm_password: Authentication for user [scan] -> [scan] FAILED with error NT_STATUS_ACCOUNT_DISABLED
ReadyNAS Duo 4.1.6
HP Officejet 8500 Wireless (using ethernet)
ReadyNAS Duo 4.1.6
