Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
miltonabove
Jul 20, 2009Aspirant
Thank you Skywalker for the help, but still no luck. This allows me to pass the HP software test during setup, but I end up getting the device freeze while saving the file, leaving a partial 17kb file on the Duo, just as many others have reported. I have guest access enabled on the share, and default read/write for all CIFS, AFP, and HTTP/S. Advanced options shows the share name as the share folder owner. Here's what the Duo log shows (blue is my added notes):
[2009/07/20 20:42:55, 2] auth/auth.c:check_ntlm_password(319)
check_ntlm_password: Authentication for user [baduser] -> [baduser] FAILED with error NT_STATUS_NO_SUCH_USER (HP Software testing, with PASS)
[2009/07/20 20:44:09, 2] auth/auth.c:check_ntlm_password(319)
check_ntlm_password: Authentication for user [baduser] -> [baduser] FAILED with error NT_STATUS_NO_SUCH_USER (Initiation of test scan)
[2009/07/20 20:44:27, 0] smbd/reply.c:reply_write_and_X(3118)
write_andX: (OS 8) End of header assumed at 64 but was at 59.
[2009/07/20 20:44:27, 0] smbd/reply.c:reply_write_and_X(3122)
write_andX: SMB headerlength of 59. Fall back to regular write reading 10068 bytes
Miltonabove
ReadyNAS Duo, 4.1.6
HP Officejet 8500
Miltonabove
ReadyNAS Duo, 4.1.6
HP Officejet 8500
