Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
Skywalker
Jul 21, 2009NETGEAR Expert
If you're using only Windows clients for CIFS on the NAS, it's safe to install this addon and see if it can make a positive difference for HP scanners. However, there are some notes you should be aware of:
* This addon will change settings which will greatly reduce performance on non-Windows CIFS clients.
* If the addon causes problems for you, you can reverse the effects of it by installing it again.
* The addon will need to be reinstalled after each firmware update.
