Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
gPAQ
Jan 06, 2010Aspirant
casper wrote: Thank you very much for help.
I will be the first to confirm that this addon finally solve the problem with Digital Filing / Network Folder.
Casper
ReadyNAS Duo , RAIDiator 4.1.6 [1.00a043] , HP Officejet Pro 8500 A909g , Vista
Hmmm... you seem to have more luck than I did. :cry:
I applied the same patch, but now scanning into my 'scan' share hangs my printer forever. I seem to have almost the same equipment and configuration you have (I have ReadyNAS NV+). Can you advise how you proceeded? Did you install the add-on and reboot the NAS, did you leave the share or did you create a new share, did you recreate the settings on your printer also? And general question: does this add-on show on the ReadyNAS add-on page with any type of interface, 'cos on mine it does not show after a restart.
