Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
gPAQ
Jan 06, 2010Aspirant
Skywalker wrote: The addon won't show in the installed addons section, since it's just a configuration change addone. It should, however, leave a message in your system logs informing you of the change it made.
If that is the case, then this update may not have worked as desired. The recent entries from my log are shown below:
Mon Jan 4 20:26:04 EST 2010 System is up.
Mon Jan 4 20:25:23 EST 2010 Successfully changed share settings for Data share.
Mon Jan 4 20:23:44 EST 2010 Rebooting device...
Mon Jan 4 20:23:43 EST 2010 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
I do have a share with Share name "shared" and for which the Description is "Data", but the target share should have been my share with the Share name "scan" and Description left blank. Any way to correct that? Per your earlier description of the effect of this add-on I'm now afraid that my "shared" share may be operating at reduced performance, and it happens to be my most significant data volume... Can this add-on be corrected, or un-installed? Your efforts are most appreciated, but I'm losing some control of my system if I can't tell exactly what's installed and I can't uninstall. Thanks!
