Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
Skywalker
Jan 17, 2011NETGEAR Expert
The data won't be touched unless you have the button held down for 30 seconds. And even then, you'll have the opportunity to pull the power plug without affecting the data for another 10 minutes. It won't change anything on the flash; you should still be running 4.1.7 after this procedure, but a few of your settings will be reset to defaults -- things like admin password, jumbo frames, static IPs, etc. But for a basic setup, the only thing you should notice is Frontview working again, and your admin password being reset back to default.
If you're still nervous about doing this, let me know, and we can do a manual fix.
