Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
jwsandiego
Jun 12, 2011Aspirant
Re: Using a Scan To Network share (OfficeJet 9130)
Postby Skywalker » Thu Jan 07, 2010 12:05 pm
Okay, this addon [Toggle_OfficeJet_Scan_Support] should be more thorough. If any share has write optimization disabled, it will re-enable it. If there are no shares with disabled write optimization, the addon will disable it on the first share found matching any of these names (case-insensitive), in this order:
HP-Documents
PDF_Data
Scan
Scans
Data
Share
>>>> I tried this with my new HP8500 Pro. (I have ReadyNas Duo, rel 4.1.7), configured a share "HP-Documents". but no luck, I still see the same 17KB file showing up and the printer freezes.
is there a way to check whether the add-on is installed properly?
I have also rebooted the ReadyNAS one more time, but no luck.
Thanks for your response.
HP-Documents
PDF_Data
Scan
Scans
Data
Share
