Tank1
Dec 11, 2006Aspirant
Using a Scan To Network share (OfficeJet 9130)
Hi i am struggling with trying to get a Hp OfficeJet 9130 to scan direct to my Infrant ReadyNAS NV. I have created a share, given it a password. I can connect to it using a xp box no problem. In...
kenalker
Aug 16, 2012Aspirant
I just used "Scan to a Network Folder" successfully for the first time in several years. I recently upgraded my NV+ to 4.1.9. I also upgraded my HP Officejet Pro 8500 A909g firmware from DLM1FN0924AR to DLM1FN1006BR. I don't believe I have installed the addon (although it is possible, and I've since forgotten).
Skywalker: 1) Is there a way for me to tell if I've installed this patch, and, more importantly, 2) is is possible that 4.1.9 (or a previous version) fixed this problem (the release notes do not indicate that it did).
