Aranol
Aug 24, 2018Aspirant
Using RSYNC over SSH to replace NETGEAR Replicate services
Hello, I Try to use the RSYNC over SSH to replace the Netgeat replicase service that stop end 2018
I have follow this tuto https://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-wi...
- Sep 09, 2018
Have you solved your problem? You can try this method, as shown in the figure: checked "Allow shell access" and unchecked "rsyc only" option.
JohnCM_S
Aug 24, 2018NETGEAR Employee Retired
Hi Aranol,
Welcome to the Community!
The RSYNC for the destination share folder might not be enable. You may check that by going to the settings of the destination folder then go to the Network Access Tab. The RSYNC default access should also be on Read/Write.
- AranolAug 24, 2018Aspirant
Hi, no there is one of the share that have RSYNC enable on read/write (with no password protection)
Any other idea ?
