Aranol
Aug 24, 2018Aspirant
Using RSYNC over SSH to replace NETGEAR Replicate services
Hello, I Try to use the RSYNC over SSH to replace the Netgeat replicase service that stop end 2018
I have follow this tuto https://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-wi...
- Sep 09, 2018
Have you solved your problem? You can try this method, as shown in the figure: checked "Allow shell access" and unchecked "rsyc only" option.
Aug 24, 2018Guru - Experienced User
Aranol wrote:
I don't see the destination NAS shares
The destination is remote? If so, are you selecting "Browse" next to the share entry and that isn't working correctly?
Did you try entering the path (for instance /data/Backup)?
Aranol
Yes the destination in remote
When I click "Browse", it first ask me "Connect As :"
Here I have to put the user I creat on the remote nas associate with the SSH key (and this step work)
Then I have a 2nd windows "choose a folder"
but the only line in that liste is "root" (and I have no root share anywhere"
and I can't select that line
And when I click on "Select" buton nothing happen (probably because nothing is selected"
There is also a button to creat new folder on that page, that give me an error message to select a parent folder node first
- StephenBAug 26, 2018Guru - Experienced User
So what happens if you don't click "browse" and just enter the path from the keyboard?
- AranolAug 27, 2018Aspirant
This is the screen I have after clicking on "browse"
If I don't use it, and use the "test conection", I've got an error message "impossible connection with host"
I also made test with classic RSYNC protocol on port 873, it work perfectly fine, but it's less secure
