Penge58
Sep 16, 2015Aspirant
Using Rsync
Hello. I want to use Rsync to make a backup or replication of a Synology NAS. I have done this before but not to a Netgear ReadyNAS. So the source is a Synology NAS and the destintion is a Read...
Sep 16, 2015Guru - Experienced User
The settings in this post should work with Synology too:https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/How-do-I-rsync-a-ReadyNAS-share-to-the-same-share-on-another/m-p/982539#M10704
Just reverse source and destination, since Synology would be the remote source, and the ReadyNAS the destination.
- Penge58Sep 16, 2015Aspirant
Thank you Stephen. I will try it and let you know.
This is the setting on my ReadyNAS.
I have created a shared folder called BACKUP_NAS3 and set the network protocol as shown.
This is infact all I have done on the destination NAS.
Is this all I need to do on the destination ?
- StephenBSep 16, 2015Guru - Experienced User
If you are running the backup job on the ReadyNAS, then you shouldn't need to enable rsync on the share (but it does no harm).
If you are running the backup on the Synology then you do (and I think you've done all that's required).
