callowell
Nov 12, 2015Tutor
V4.2.28 firmware update failure
Re your email update notification 11 November 2015 All attempts to 'upload and verify' (local from your download) fail. I have A ReadyNAS Duo RND2000 Current firmware 4.1.14 Please advise
JennC
Nov 12, 2015NETGEAR Employee Retired
Hello DrawsACircle,
Welcome to the community!
What is the FW version you are trying to upgrade to and the filename (include extension name) that you are uploading?
DrawsACircle
Nov 12, 2015Tutor
I'm trying to upgrade to 4.2.28 - the filename is: RAIDiator-x86-4.2.28.zip (similar to firmware version 4.2.23 and 4.2.25 filenames)
- JennCNov 12, 2015NETGEAR Employee Retired
Hello DrawsACircle,
You need to unzip the folder then you will see 2 files inside. Release notes (HTML) and the firmware file. Use the firmware file, upload it to the NAS via FrontView.
- DrawsACircleNov 12, 2015Tutor
I don't recall unzipping the other files - been a while since 4.2.27 - it works :-)
Hello DrawsACircle,
I downloaded the firmware myself just today and it appears to be a ZIP file, unzipped it and found 2 files, the release notes and the actual firmware file.
