svicas
Oct 18, 2015Aspirant
Vertical Expansion of Ready NAS with RAID5 by mistake
We are currently using Ready NAS 1100 with 4 hard disks (1TB, 750GB, 1TB & 750GB) with RAID5 configuration. Without knowing this fact, we tried to expand the hard disk capacity by inserting 4x2TB HDD...
- Oct 26, 2015
4.0.1 firmware was released back in medieval times, and doesn't support 2 TB drives.
Upgrade to 4.1.14. To get full expansion and best performance you will then need to do a factory reset, rebuild the NAS and reload the data from backup. That's because the block size needed to change in order to support 2 TB disks, and that can't be done w/o destroying the data volume. Also, ideally you want 4K sector alignment (which also requires a reset).
http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-sparc-readynas/
Oct 19, 2015Guru - Experienced User
What firmware are you running?
Is the RAID set up as XRAID or FlexRaid?
- svicasOct 26, 2015Aspirant
Firmware: RAIDiator 4.01c1-p1 [1.00a146]
Raid Level 5
- StephenBOct 26, 2015Guru - Experienced User
- Sep 06, 2016Retired_Member
