Rimbalza
Jun 20, 2018Aspirant
Very poor performance on iSCSI
Starting situation: Windows 2012R2 with MPIO with 2 gigabit adapters. RN316 with 6.9.3, 6 Drives full.
When a backup starts from the other NAS (same model) to this one (both DR or rsync) the iSCSI ...
Rimbalza
Jun 21, 2018Aspirant
Thanks for your reply, but I'm not using SMB and tested sync writes on and off ono iSCSI too with no success.
Today I'm trying to run a backup and I get horrible performance and not constant. In the graph below up is IOPS and down Network.
It goes up, then drops and then slowly gets better, but nothing acceptable.
We'll dump Netgear stuff asap...
mdgm-ntgr
Jun 21, 2018NETGEAR Employee Retired
What about CoW, bit-rot protection and snapshots? Have those always been disabled on this LUN?
Is the LUN thin/thick?
- RimbalzaJun 21, 2018Aspirant
You can find the relevant info in the first post.
BTW, no CoW and compression, thick LUN.
Edit: and no snaps
Right now I killed the long running backup, it will terminate in a month at this rate. I tried to offline the LUN from Windows disk manager and it is hung since 30 min.
This is pretty reproducible, when some sustained iSCSI activity is ongoing all other iSCSI tasks also on other LUNs & portals just hang crashing the apps on them.
I did the same things on the other identical device but with 6.9.0 and is is the same. On this unit also MPIO never catches up, only one link is used despite both being configured.
I repeat this again, the same servers on other vendor's devices on the same gear pump full gigabit speed and several times balanced MPIO reaches 1,5/1,7 gbit.
